At last, 'new build' quality improves ...
I refuse to work in any property built past 1990.
Even for friends and family.
You start with a simple job and you end up spending a week fixing stuff.
That silicone around the pan is the best example.
Remove it to do a better job= 15 minutes.
Then realise toilet is not fixed.
It also leaks from the waste and it takes 20 minutes for the cistern to fill due to kinked pipes.
Strip everything and start again.
Until you find that the pan is cracked...
Off to the shops again...
This actually happened to me.
These builders win awards. I see one today.
Average cost for a brand new house
£300 400,000?
If someone building you a brand new BMW £40 100,00,
Would you accept workmanship like this?
No ..... no one would. So why do these building companies get away with employing low skilled cheap labour like they do?
I don't fancy anything younger than 1968.
Having said that, there's a few structural issues with my gaff and that was thrown together in 1960.
Apparently the purlins are horribly undersized, but the whole estate is like that. I can't be the only owner with the problem, which is a spreading roof.
I think our building industry has always been bad but it's worse now than it's ever been.
Whenever I get a bit worn down from the ongoing project I've set myself with our solid but tired 1950s house then I watch a couple of this bloke's videos for motivation.
His business is making snagging videos for the no doubt traumatised people who've just paid many £100,000s of borrowed money for these things, I guess his voiceover is far more serious on the videos that are presented to his clients, the builders and probably the courts. Housebuilding is a scam industry these days.
Yes, we definitely did make the right choice by buying older.
