Hi guys
In the process of getting an Atag A series boiler installed and have a few questions.
1. To use the weather compensation sensor alongside the boiler do you *require* the Wize controller or will any volt free room thermostat suffice?
2. Is it possible to control the boiler without a room thermostat and use the ext weather sensor exclusively e.g. no controls at all except for those built into the boiler?
3. This is where I may have gone wrong but ordered the boiler with the flue pack, seems have an extra flue with it. A PP 60x100 and a 60x250 with wall terminate end plate.. did I need both parts? Boiler will be fitted onto the external wall and flue exit directly above boiler hopefully.
Any help is appreciated... the installer I was using seems to have gone AWOL as well currently sourcing a new installer.
