Have called the guy who installed it to come and take a look at the beast, but in the meantime does anyone have any ideas based on the following symptoms?
ATAG A325ECX condensing boiler installed ~18 months ago. Heating system is a three loop job, each loop guarded by a valve controlled by a Honeywell radio control & remote thermostat pair.
The boiler fires up and delivers piping hot water, but refuses to fire up in response to a request for CH from the thermostats. The little rad symbol appears on the boiler control panel, so it is receiving the request for heat, but refusing to fire up. There are no errors reported by the boiler.
After running the hot water tap for a few minutes, both the CH inflow & outflow pipes become warm, especially the return pipe between the expansion tank and the main body of the boiler.
Poking the boiler CP after running the hot water tap reveals that it believes that the temperature of the CH inflow & outflow are both simultaneously almost equal & high - often around 55 degreesC. I suspect that this is why the boiler isn’t even bothering to fire up - it thinks the hot water return temperature means that there isn’t any point.
Any thoughts on a likely cause? Some googling around suggests that the diverter valve is a likely cause. Any other possibilities, or things I can do to test this hypothesis?
cheers all, Phil
cheers all, Phil
