I read in PE aboout this cable and doubts about it's compliance, any one know which outlets supplied this brand as I have seen a lot of poorly maked T&E of late
DM
Its the singles that **** me off - A few years a go a brand new drum would still have an inch of cardboard on the drum to prevent the able from slipping of the coil.
The newer drums have the cardboard drum sut the same height as the last coil - meaning when you have your drums on a stand and pull, you always end up with one cable slipping off and coiling around your bar.....you then need to get back off your steps/scaffold etc and sort it out again. Atleast for the first good few meters!
