B
Brightonguy
I see. To stop boiler cycling.
I looked at Youtube and saw some vids on the Atmos/Intergas. The man boasted that the combi had a standard off the shelf pump that only does the CH and not the hot water as it is not needed for hot water. A great advantage of course as these are cheap and any make can do the job. It has just stuck me that if this was replaced by a Grundfos Alpha, or Wilo equivalent, and flow switch on the heating flow pipe and have rad valves on all rads, even the bathroom rad, then there is no need for room two stats. Would Atmos/Intergas go along with this? Also the pump, would modulate down if only one zone is on and not running too fast.
Dan, do you care to comment?
