Attaching a boss to orange soil pipe - solv. weld or strap?
8 Feb 2010
Berkshire
Have to make a connection to a short length of vertical orange soil pipe under the ground to take a 32mm pipe - would I use a strap on or solvent weld boss for this? Was going to use a 50mm boss with a pushfit reducer to 32mm. Any other way of doing this?
Make sure you fit by the regs - can't connect into a soil pipe less than 450mm from the base of the bend at the bottom of the stack.
Hope that doesn't cause you an issue.
Yeah, Hi Kev :) Have you seen Dangermouse, Penfold :?:
Thanks for the replies and for mentioning those regs - that won't be a problem here, but they were worth mentioning all the same. :)
I just join this forum and read this topic. I want to know how it will be connected.
