My kitchen diner is 9 metres long by 3.6 metres wide
7 metres of the floor is suspended and I'm going to t&g chipboard over the joists, the other or last 2 metres is concrete which isn't flat, I'm going to build a stud wall over about 1.4 metres of the concrete part to make a utility room and a downstairs toilet, I also want to tile the toilet , utility room and about 3 metres or so into the dining room (this will form the kitchen area) the rest of the dining room will be laminate
I've got the joists ready and built them so that the concrete will end up slightly lower (about 5 mm) from the top of the chipboard, this is so I can use some levelling compound to get it flush
my question is really about the best way to level the concrete and to tile between the two areas
my thoughts are to screw and seal a baton across the concrete then level the concrete flush with the chipboard surface then tile directly onto the chipboard and concrete using the appropriate bonding & grout for each surface (or an all in one if there's such a thing?)
the problem I envisage with this is that water could get into the chipboard and damage it (even though it is P5)
my other thought is that I need to put some kind of backer board onto the chipboard to make it water proof then level the concrete flush with the backer board then tile it
if anyone can offer any advice ?
I've so many questions such as, which backer board to use (if I go that direction)
how to attach it?
how much extra will it add to the height of the floor?
which levelling compound?
if I insulate between the joists would backerboard affect the moisture that needs to evaporate from the void thus causing damp and rot?
probably many more to ask as i go along
one final thought is that I should just scrap the tiling and only tile the utility room/ toilet and just laminate the whole dining kitchen area, but I suspect this could lead to more problems with water ingress
how to attach it?
