yes there will be a dpm/vapour barrier but this will be at ground level..i.e
soft sand..then
dpm/vapour barrier..then
concrtete..then
your block beam..(suspeneded)..
so i would lay a dpm then screed s/c ontop off the b/b...
tile and leave a perimeter joint around the walls.
you have already removed the(dpm) from the floating floor...so you will have to replace this...
i am just a tile fixer mate not a biulder.. :wink
soft sand..then
concrtete..then
