Let us know how (and where) you get on.
. ...and they don't try and steal your "precious" when you visit them...unlike some stores....
I bought from homebase ‘Westco’ engineered oak 3 strip glueless 14mm was £19per m2. However i aquired a 20% off voucher which brought it down to £15. Not bad at all! Also bought my underlay, and sliding wardrobe doors too taking full advantage of the discount. All ready to take away that day with plenty in stock if i needed more!
That was the good news.
Now the bad news.....
the flooring is a glueless type which doesnt just click together but has to be literally bashed together. Within 10 minutes i destroyed my plastic knocking block and bent my pull bar.
Having spoken to Westco, i was told i needed heavy duty tools, so i spent another £30 on a new knocking block and pull bar.
After 4 days i have only completed 2 of 3 rooms and partially deaf from all the banging.
Looks great down, but with all the banging sometimes it would cause movement somewhere else so i have a few very tiny gaps which are irritating.
Hope this helps somebody
Gollum's ring.
the flooring is a glueless type which doesnt just click together but has to be literally bashed together. Within 10 minutes i destroyed my plastic knocking block and bent my pull bar. Hope this helps somebody
[The Timberland kind of companies are giving the honest and professional wood flooring trade a bad name!
Yes, it certainly does help me. My very first post in this forum was on this topic. I'd bought laminate and virtually everyone told me I couldn't click it together because I'd gone for the cheap stuff. Homebase, by contrast, tried to tell me I was incompetent - apparently no one else had complained. Your story suggests it's not just the cheap stuff. Please, please, complain to Homebase. If enough people complain, they'll change the manufacturers with whom they deal. If no one complains, they think everything is OK.
Westco is the stuff I bought from H/B but I paid £13.95 a while ago. Regards fitting; I had the same problem initially but then tried a little soap which made assembly much easier. The odd pack was still a little too tight though & in the end I gave the toung’s a couple of passes with 120 grit which did the trick. I did 3 rooms in 3 days & it’s been down for just over a week now & it looks great with no gaps to speak of & nothing popped out! Just refitting the skirting & architrave.
Gollum's ring.
"A*al Virginity" ? ....isn't that a bleached oak shade in B&Q's Aqua Loc range ?
