First off. A big thankyou to all of you who post here for your time and expert advice. I have successfully dismantled my system, cleaned every radiator, installed deaerator on flow and dirt separator on return added new radiators. Well done to all of you that have posted through the years as I trawled extensively through the posts to decide on best practice. All working well touch wood!
I am now balancing the system and have trawled through the posts re balancing. My question is for the more technically minded really.
Does anyone know where the value of 12oC comes from? Surely the drop in temperature between the flow and the return should be a relative value rather than an absolute value?
For example I have set my boiler to heat the CH circuit to 57 degrees (trying to get it as low as poss to save on heating bills) and so 12 degree drop in temperature is higher relative to this flow temperature when compared with a temperature drop in a system set to a flow temperature of 80 oC?
It is a combi system (Vaillant ECO TECH 837 Plus).
