TL;DR - I want to balance the radiators, but not sure what sort of temperature drop I should aim for across each rad. I've looked in the boiler user guide and also the installer guide, but I can't find anywhere that says what the flow and return temps need to be.
Background:
I have 2x radiators in the lounge and both are hot to the touch with no cold spots anywhere, but one of them doesn't seem to put heat into the room even though on the affected rad I can measure a temp drop of ~17 degrees between lockshield and TRV - it's on full blast with the TRV always open, trying to hit our target temp... but the room often feels cold. We moved in during the summer, but since it's been so cold over the last couple of months we're looking to try and improve things.
The space I'm trying to heat:
The room is open plan with 2 sections, and total volume of the room is:
(3.0m x 2.8m x 2.4m) this is "the nook"
plus
(4.5m x 3.9m x 2.4m) this is "the lounge"
That makes total volume 62.28m3 (I think! Please forgive me if my maths is wrong! )
The lounge & nook are downstairs: it's a really old property without cavity wall on the lounge side (which is maybe the problem), with suspended floor. It has a non-functioning chimney - there's a chimney breast, but everything above the ceiling level has been removed. I've used a "Chimney Sheep" to stop warm air escaping to the room above. We have modern double-glazing in the nook, and brand new double-glazing in the lounge. There's a door out to the conservatory which loses loads of heat - so we have a curtain drawn across it pretty much permanently (new doors being installed soon, but we'll have to make do with the curtains for now).
The radiators we already have
1x type 21 (0.6m x 0.6m - unpainted) on an internal wall in the nook (thoroughly cleaned behind, and between panels)
1x type 22 (0.9m x 0.6m - unpainted) on an internal wall in the lounge, (thoroughly cleaned and dusted behind, and inside/between the convectors)
The problem
The radiator in the nook is doing ok, but the lounge one never seems to get above 21deg (21.5 if we're lucky) - we're using Honeywell HR92 TRVs to measure the 21deg figure. The HR92 in the nook happily gets to our target temp of 22 and beyond, but even increasing boiler temp doesn't seem to help for the lounge (CH temp on boiler is currently at about 50% - I increased it to nearly full the other night, and I got maybe an extra 0.5deg, but I want to see if there's a better (cheaper) way to improve the heat output from this rad). I know I can adjust the offset of the HR92 if I wanted to - but it'll still feel cold in the lounge, and that's what I want to fix. The lounge takes ages to warm up, and often feels cold (while the nook isn't affected by this problem). The heating comes on at half 6, and the Honeywell tries to maintain a target temp of 18 during the day (boosted to 19 when it's below 10deg outside), up to 21 in the evening (or 22 when it's cold out). On a weekend the target temp is 21 (boosted to 22 when it's cold out) the whole time. The heating has been running like this for a few weeks now.
Maybe we're going to be limited by potential heat loss through the walls and floor? It's been dead cold outside lately, but wondering if anything we can do to improve heat output, and I wanted to try balancing the rads in case that makes any difference.
Background:
plus
The problem
