With a condensing boiler its much more economical with a lower flow temperature so the rad specs should now be quoted for a delta T 50°
In reality its possible to get more heat out by turning it up just at extreme cold times as long as you reduce it later. As it doesn't condense its about 12% less efficient.
Ideally your boiler should be used with a flow of no more than 70° and lower if you can get enough heat out.
The return should also ideally be 15-20° lower than the flow temperature.
Tony
Tony
