Ball Park Price Please
12 Mar 2018
f anyone could give me a rough ball park cost for the following work that would be great. Had two very different quotes and wanted to see who is more realistic
Supply and replace 3 port valve head on cylinder
Supply and fit new cylinderthermostat
Rewire central heating controller to provide independent control of heating and hot water
Manual flush of 5 radiators
Thanks a lot
Update
Had rads flushed, Loads of gunge came out. System drained and refilled. New three port valve on but not wired yet as sparky didn’t turn up lol
Heating on and still same problem. Two rads nearest cylinder red hot and fill pipes to others red hot to touch but rads themselves not working well at all
Popping noise also in the ones that are on
Driving me mad, could it be the pump?
Images of set up here. Be warned, it’s a mess
https://postimg.org/gallery/tnxl6on8/
New cylinder stat to be fitted and the valve needs wiring to the Honeywell programmer
Does that make sense?
No. I would expect any plumber or heating engineer who takes on the job of installing those items to be able to cope with the wiring too. Would be doubting their competence if they couldn't.
