OK - I'll try not to confuse the end of the cable with a sherbet fountain....As far as I know magnesium oxide is more or less harmless unless you go chugging it.
No - only with the slippery wet ones.But you are of course wearing latex or similar gloves while working with powdered substances anyway.
Any ideas why here:I was told a foot iirc, although the only real way to tell was to strip from either end and have the IR tester on it periodically.
Curse you, now I need to go find someone who still sells those..
The new plastic tubes are nasty, though. Bring back the cardboard.
Hmmm....The new plastic tubes are nasty, though. Bring back the cardboard.
Only if we can not bring back them ever being stored in damp conditions so that the sherbet goes all lumpy and won't go through the straw....
I'm sure you've thought of this, but it would presumably not be wise to chop back that end too many times before attacking t'other end - since there's no telling what may be going on underneath that glue.The cable is a full reel, and one end is (or appears to be) nicely sealed with some kind of glue - the other end has traces of that but most had broken off.
I cut back about 100-150mm from that end and zapped it - got between 25 and 40M core:core and core:sheath.
I'll chop more off and have another go.
I suppose you could try a hair dryer or (carefully!) hot air gun - but I suspect that would carry the risk of making water vapour travel in the direction you don't want, thereby doing harm rather than good!The cable has a PVC cover, so I can't try a bit of blow-torching at the end.
