personally i cant see the problem with rings, we all know of the 'danger' when one is broken and agreed the breaks are often caused by DIYers............ but if done correctly then after working on the circuit (even changing socket fronts) continuity of conductors should be proved.
suppose you could make a case for instances where conductors burn away from the terminals but this i would think is rare and is the reason why PIR's should be performed at the times recommended.
