plugwash said:finally while looping in at the switch may be easy enough for single switches i would hate to do it on a triple
quote]
its not too bad, if its 3switches on a single 1 gang plate, use a 35mm deep box
if its 3 switches on a double plate, you've got nothin to worry about!
They would be if every luminaire sold in the UK used them....fubar said:ban-all-sheds said:It would not be rocket science for manufacturers to place a terminal block which matches the connectivity of a ceiling rose where they normally put a bit of 3-way choc-block.
Are such terminal blocks even available (other than integral to roses)?
