Banging Noises In House
What about the wind?
Could it be blowing something above the ceiling?
Definitely not the wind. Thought about that already. There's no wind when it happens. I try to stick my head outside when I hear it to see if I can hear it outside but I can't.
At the end of the day, it will be a simple answer. So once you do find out what it is please come back on here and let us know.
In the meantime, keep a diary of times and days when it happens and speak to all of your neighbours to ask if they have any strange noises.
Andy
Andy
I will do. I just hope it vanishes as quick as it appeared!
I will report back when/if it goes away.
And to top it off, my kitchen sink cold tap has no pressure. It's just trickling out all day. All other hot & cold taps, showers and WC are working fine. This one may be easier to fiqure out though than the bangs.
Your kitchen tap should be the best workingtap in the house as it is under mains pressure.
You said earlier you have a combi boiler so no hot water tank or tank in the loft. Strange how all the other taps/showers are working normally.
Once you have eliminated/discounted all the possible physical reasons then it's time to investigate further.
Although the land was previously allotments it may be an idea to research it's history. How long was it allotments? Did anyone die on their allotment?
What was the land before allotments? It may have been a small village in the 18th/19th century where a tragedy happened. Local council offices may be able to help or even local church records.
It's a goast then
Whats a goast ?
The banging problems we had I believe we're caused by having swietenia mahagoni bought from where the ruby player had the issues when he was alone. We got rid of it and the problems stopped ........Prior to us having problems I gave some to a friend and they started having odd unexplainable things happen so they brought it back !......I thought he was imaging things and they were a bit nutty. Until things started with us it was very old timber black with age.
Stating the obvious perhaps, but record the sound next time you hear it. At best it might help you identify the cause, at worst when the investigators come to work out what happened to your body they'll be better prepared for the possibility the goast did it.
