So to sum it up heating is off, no hot taps running, no cold taps runing, in fact NOTHING running or working and you still get this banging that we now assume is water hammer
I don't know if we've had an answer to the question about what your previous system was Did you have a combi or was it a conventional boiler and hot water cylinder fed from tanks in the loft?
If it was cold tank fed could this be a toilet ball valve (probably bathroom) that was on low pressure but is now on your high mains pressure but hasn't had the high pressure adaptor fitted?
Any other drips or leaks you haven't mentioned?
