I`m sure that others must have had some barmy customers?
I will start of with three:-
1/ Customer asked me to reroute an existing cable - trunking in a pantry/cupboard under the stairs on the inside of a door frame, out of sight if door closed but if door open it showed up (white trunking) on white door frame at the opening side and the door head therefore restricted open are by 16mm both width and height on a full size door. Door opened outwards into the room.
His reason was "If the door is open and someone hangs their jacket on the open edge then tries to close the door it will knock the trunking off.
I did explain I would need to replace with longer length of cable and trunking to reroute to another satisfactory route therefore expense etc.
His wife asked him which idiot did he think would hang a jacket on a door then attempt to close it?
2/ Demonstrating an intruder alarm system I put it into activation and the customer objected that it would disturb the neighbours. His Wife replied that she hoped it would indeed disturb them if activated.
3/ An intruder alarm again (not one of mine) Bloke says what is the point of putting a bellbox on the front wall because they will just break in round the back?
