Hello
Am about to install a ring main and lighting circuit in a habitable basement. All walls are painted - unplastered - brickwork, dry and sound. Dry concrete floor, exposed timber ground-floor joists in ceiling. As the sockets will be 500mm above floor, I want to run ring around perimeter at floor level and vertically up/down to each skt. Cannot chase into walls or floor, so all has to be surface mounted.
Question: Do I need to run all exposed wall borne-cabling in round plastic trunking/T-junctions or can it just be clipped neatly to the brickwork and painted with a PVC friendly white paint?
CU also located in this basement mounted in middle of one of the same walls. Plan to simply clip cables and cover/box in for short distance from ceiling space down the wall to CU.
Many thanks
Many thanks
