I might need to lift the bath marginally, but hopefully it will fit. I didn't want to use this trap to start with as i know it is too shallow for building regs, and being above the boiler feed/return I fully expect it to evaporate and break the water-seal.
However if I use that trap purely to lift the waste outlet high enough, I might then be able to use the HepVO as an inline horizontal waste....
Hmmm... time to buy the straight couple for the HepVO I think and get trying it again
Lift the bath to a height where you can get the waste/trap fitting properly (use 3"x2" bearers) fit the bath panel and get some skirting board or quadrant to take up the gap at the bottom.
