Moved into new house. Diffculty draing bath. Drainage pipe appears to point angle upwards into main drain. Should the drainage pipe be connected like this ?
No,should always drain downward or fall away,not sure when you say connected into main drain,need more info,upper,lower floor level,waste pipe out to wall then what happen ? Are you saying the main drain is higher than your bath level ?
