Hello,
I was wondering if anyone could help. I've got a cheap bath shower mixer I bought from Screwfix last year.
I fitted it with mains cold and stored gravity hot and found that it didn't mix the water very well so I changed it to gravity hot and cold.
I then fitted a whole house pump to boost the pressure but I still found that the shower temperature adjustment was far too sensitive. A little turn of cold would send the whole shower freezing.
Normally when I've used bath shower mixers you set the tempertaure through the bath tap bit and when you're happy swap over to the shower.
With this mixer there seems to be no relationship between the temperature of the water coming out of the tap and the shower mixer.
What could be wrong?
Thanks in advance for your help!
