Mixer tap showers - advice required
From (my sample of 1) MI :
"Not covered by this guarantee - Damage or defects arising from incorrect installation"
I would argue that failure to be installed by a qualified electrician semantically means that it is prima facie an incorrect installation
But to succeed in that line of argument, you'd have to prove that no unqualified person could ever install the product correctly.
After all, the Triton MIs that I'm looking at here are surprisingly comprehensive (given that I didn't even open them on Thursday when I installed the shower), and an undersized supply cable, which is one of the more likely errors that an amateur would make, won't have the slightest effect on the shower in the context of a warranty claim.
So you don't hold with the argument "correct installation" if and only if "qualified electrician"?
Are you qualified? :rolleyes:
Joking apart, in reality, true. But the possibility, no matter how negligible, exists.
In that case why did you write "to hell with Part P"? :confused:
Because I don't know what the Scottish equivalent is called or even if it currently exists (though I know it has been proposed).
You still have electrical fires though, right?
Not so far :) No doubt you still have electrical fires in England despite part P (and I bet the number hasn't significantly changed since its introduction).
To reiterate: how will you calculate the correct cable CSA to use?
I would use the size of cable recommended in the installation instructions and double check with the wiring regs to see whether the size is appropriate for my installation taking in to account the wattage of shower, the length of wiring required from shower to CU and the route that the cable would need to take (whether enclosed etc).
IIRC, 10mm CSA is sufficient for even high power showers in just about all domestic situations.
Of course not.
Are you qualified?
To do what?
What was that for? :confused:
Erm, you've lost me - the possibility of what?
________________
Well, to put it another way, why did you write something that implies a cavalier approach to safety?
Are you talking about the [relatively] new notification aspect, or the requirement to install safely?
The delay in your reply was roughly equivalent to the time needed to look up the answer, so I remain unimpressed.
Yes, all situations except those in which it's inadequate. :rolleyes:
Of course not.
We disagree then
Are you qualified?
To do what?
To install that shower
To indicate irony in the context of this post - unnecessary and irrelevant. I apologise
"the context of a warranty claim"
We disagree then
No we don't.
Are you qualified?
To do what?
Of course.
I apologise
Not needed, but thanks.
Oh OK. I agree that it does exist, but I don't agree that such a claim would be rejected out of hand because there was no evidence of a installation by a qualified person.
I don't care - why would you expect someone who isn't a sparkie to memorise information such as this - that is what reference texts (and the internet) are for.
Of course not.
We disagree then
No we don't.
Huh?
Have you misworded this? Do you mean "wouldn't be rejected"?
Apart from that I think we've nearly exhausted this topic now.
:D
I don't think so, but I suspect we've exhausted that mini-thread anyway.
And there was me thinking the same thing. ;)
