The problem I think has been there for a while.
It's been made worse because I have a bath every evening and a shower in the morning. I don't think the previous occupant did.
When my dad siliconed it he filled up the whole cavity behind, he forced the strip off to do this. Unfortunately this has caused more water to access the area and the mould to become worse. His intentions were good, but it's caused the end of the strip's life. It turns out to have been a blessing in disguise as the strip is glued on and not underneath the tiles. The strip had grout between it and the bottom tile, making it look to everybody (including a tiler) that it was one of the strips that goes undeneath.
Now that it's popped off I've been able to clean out behind it (and open a window to get rid of the awful smell) and a tiler is coming tomorrow to tile the 1 inch gap.
I perhaps could tile, I understand the basic principles of it. and I didn't realise it was quite as cheap as that!
I think though that I'll spend the £100 (the tiler wants 50 for the job as it's 2 visits) and get just that strip done.
I think it'd be a particularly difficult first tiling job for me to try. The bath itself isn't level with the wall - the door is very tight so some of the wall has been removed and the bath is slightly inset. The gap varies from 1 inch to 5/8 of an inch meaning I'd have to cut the tiles carefully. Tiling that strip is essentially just all the difficult tiling tasks rolled up into one.
Tiling the rest of the room might have been a better first attempt at tiling for me though. I might later decide to whack off all of the other tiles, leaving the edging quadrant in place, and put up white or slightly marbled tiles all over the room. I've got the tiler going for the white quadrant strips of tiles, and he said £18 a pack, so it's £88 all in for it - I guess he found them cheaper than I did. It's nice and honest of him too!
The shower screen isn't too bad, it cleans up nicely, although it gets manky quick again. It's been mounted onto the door frame - yes really. However it's secure and will last another few years I'm sure. I may need to get a diamond tipped drill bit and move it, and if I'm moving it I'd probably replace it. For the mean time though it can stay where it is.
