Bathroom bonding?
9 Aug 2006
Lancashire
Hello,
If a metal towel radiator is fed by plastic pipes does it need bonding?
Also if the taps are feed with those flexible plastic pipes do they need bonding?
Is the CH system done in copper with short plastic pipes off to the towel rail? Same with the hot/cold water?
There is a short run of copper at the boiler then i beleive that the main runs are in plastic
How long a run in plastic between the boiler and the bathroom? What size pipe is this? What are the hot/cold pipes plumbed in?
