My current Bathroom extractor fan is wired to a switched FCU outside the bathroom door. As it is now very noisy it is time to change it, so I want to install a new one, which has a timer on it. I would prefer to wire the new one to the light so that when the light is turned on the extractor fan starts.
The Bathroom light is currently wired into a chock block in the loft and then two core cable goes through the plasterboard to the light.
The extractor fan is in the ceiling connected via some flexible ducting to an external grille. The new extractor fan has three connections. L, L/S, N.
Can I connect the new fan to the straight to the chock block i.e L to the mains loop, L/S to the switch wire, then N to the Neutral. Or do I need to connect via a unswitched FCU.
