Trying to connect an timed extractor fan for the bathroom.
Fan requires Switched Live, Permanent live and Neutral.
Rigged up an FCU on the upstairs ring main, connected the fan to it. Fan comes on but it switches off when turned off(ie, timer not working). Checked permanent live, it's ok. Tried taking the permament live from somewhere else, same problem...
Checked the fuse in the FCU, it's fine. Did some experimenting and discovered that the only way we could get the fan to work correctly was to wire a plug to the SL and N and plug it into a wall socket, keeping the permanent live coming from the same place as it was before. This works and the fan keeps going after being switched off!
However, bizarrely, if you insert an extension socket between the fan cable with the plug on and the wall socket, the fan timer stops working again.
To be honest, we have no clue as to what's going on. Fan works, all the wiring is correct so why will the fan only work when plugged directly into a socket? It doesn't work when wired directly into the ring main, off an FCU or with an socket extension cable.
