Bathroom light and fan wiring
my initial post was a guess. you hadn’t sent the pix of the wiring at that point!!
My rewiring plan above gives you two wires in each COM.
can’t do big drawing to map it out.
It’s easy. Follow my post above.
if it’s too difficult just cram three wires in one terminal.
Actually, when I look at these original photos, I can’t quite work something out. Why is there a wire between the Com terminals in the mirror and the light? I thought, for each of these threee devices there would be a live wire coming into Com, then a switched live from L1 going to each device? But I can’t see a wire coming in from the fan isolator.
There is a live feed in to the box and a feed out. These go to the com terminals on the mirror and light. Then there are loop wires between the three switches linking all the switches together.
