Hi all,
This post relates to the lighting circuit in a bedroom currently in the process of being converted into a bathroom. The existing bathroom is downstairs, the bedroom is upstairs.
An existing 60W ceiling rose has been removed. The wiring is recent and dates from 2004 and consisted of two cables. One to the switch and one to the ring. This appears to be a spur which I wasn’t expecting. The changes described below relate to this connection.
I am adding:
- Six 35W halogen lamps, ceiling-mounted in IP44 enclosures running from two 12v transformers. The transformers are supplied by 1.5mm T&E, 12V supply is 0.75mm twin flex connected in series to 3 lamps each. This sounds a bit on the thin side to me. Perhaps the 12V supply should be 1.5mm T&E to junction box then each halogen individually wired from this?
- One 1.5mm T&E direct from switch to a mirror heater. Approx 30W.
- One 1.5mm T&E direct to a shaver point.
- Connection to extraction fan including 35W lamp. I haven’t done this yet as I don’t have any 3 core plus earth. Is it acceptable to do it with 2 x 1.5mm T&E and if so, how?
I will also be adding a 10mm shower cable from the consumer unit which is only 8 feet away. However, I’ll be getting an electrician to do this and check everything else for part p.
Questions:
1. Should the 0.75mm flex used to wire the 12V halogen lamps be thicker or individually cabled to each lamp from a junction box?
2. If I can’t get hold of any three core plus earth, how can I achieve the same with 1.5mm T&E.
3. Do I have to have a switch on the fan, mirror heater, shaver point or shower?
Background:
This house is very cold. The loft insulation consisted of some pink rock wool around 50mm thick at best combined with the usual carpet, rugs, mats and bits of Christmas decorations dating from the 70s. This has now been cleared but has revealed 4” joists which won’t work with my shiny new 200mm rock wool as I also want to board the whole space. So, as I was given around 20 lengths of 5x2 I have now glued and screwed them to the existing joists giving me 9” and plenty of room for both 200mm insulation and boarding. All halogen lights are now surrounded by 360mm sq boxes with at least 50mm clearance and all cables are housed in at least 25mm trunking where they run near or in insulation.
I am adding:
Questions:
Background:
