More to the point, it is not acceptable unless the manufacturer says that it is.it might well not be acceptable for use in a shower cubicle if the manufacture said it wasn't
Usually three.
Sort-of, but I was assuming that if their instructions were silent on the matter, one would ask them - and then only if their response was that it was not suitable (or, perhaps, that they "didn't know") would it not be suitable.More to the point, it is not acceptable unless the manufacturer says that it is.
The instructions cannot be expected to be exhaustive, and I can't see that any law would/could expect them to be.Manufacturers have a legal duty to provide information for safe use of their products, not just to answer questions that are asked.
I'm not totally sure what you're saying. The point is that, even if it is IP65, it might well not be acceptable for use in a shower cubicle if the manufacture said it wasn't. The RCD requirement relates to anything (new) in a bathroom, but there is no requirement to bring existing items up to that standard.
If the light is to be on the ceiling, and that ceiling is at least 2.25m above floor level, then that makes it a bit 'easier', since that is outside of the specified bathroom 'zones' - which, incidentally, would also mean that it was not work that had to be notified to your local authority.
Kind Regards, John
OK. In that case, as I said, it's not 'notifiable' work, even if the light fitting is a new feature.Ceiling is 2340mm from FFL. Metal pipe feeding fixed shower head is 6" beneath the 240v light fitting. The shower head sprays downwards, in fairness.
If the light fitting (or some other one) has always been in that position, then, as I said, there is no requirement to retrospectively bring things up to current requirements by adding an RCD. However, if the light were a new feature (or if it had been moved from a different position), then there probably would be a requirement for it to be RCD-protected.Sounds like an RCD is not required (I want one anyway) and original sparks have done nothing wrong.
No, I wouldn't expect a list, but I would expect them to state something more general, such as "wet environments, e.g. bathrooms".Would you really expect manufacturers to indicate if each of their products is safe to use in a garage, shed, conservatory, loftspace, garden, patio, bedroom, bathroom, kitchen, nursery, workshop etc. etc. etc. etc.
I wouldn't expect it, but they certainly should.and for users to be expected to assume that it was not suitable for use in any environment not explicitly mentioned in the instructions??
I may be wrong, but I would think that the instructions which come with the great majority of electrical products are silent as regards the matter of what environments the products are suitable for. Do I therefore take it that you feel that consumers "should" assume that very few electrical items are suitable for use in any environment?I wouldn't expect it, but they certainly should.... and for users to be expected to assume that it was not suitable for use in any environment not explicitly mentioned in the instructions??
Opinions will probably vary, but I would suspect that many/most would probably feel that that constitutes a lot more than just 'replacement of a light'. If one takes that view, then the downlights would count as 'new', in which case there probably would be a regulatory requirement for RCD protection.There was a single fitting previously. Now there are 7 recessed down lights. The light switch was originally a pull type located inside the bathroom and now it's a switch on the outside wall so that has changed too.
It depends on the items.I may be wrong, but I would think that the instructions which come with the great majority of electrical products are silent as regards the matter of what environments the products are suitable for. Do I therefore take it that you feel that consumers "should" assume that very few electrical items are suitable for use in any environment?
Yes, but stillp seems to be making a general statement about "legal duties". I doubt that (m)any switches explicitly state that they are suitable for anywhere - so how is the user/consumer meant to interpret that? By analogy with what you're saying about bathrooms .... !!As you know, no switches state they are suitable for bathrooms. Therefore we cannot assume that they are as far as the manufacturer is concerned.
By presuming that they are not suitable - as far as the manufacturer is concerned.Yes, but stillp seems to be making a general statement about "legal duties". I doubt that (m)any switches state that they are suitable for anywhere - so how is the user/consumer meant to interpret that. By analogy with what you're saying about bathrooms .... !!
So most switches are not suitable for use anywhere? I don't need to tell you that that's just plain daft!By presuming that they are not suitable - as far as the manufacturer is concerned.
Yes, but in the context of this thread, it's not as simple as that, is it? I thought we were talking about regulatory requirements (a.k.a 'what is allowed', or 'what BS7671 requires') and the answer is/was that the regs require that the item in question be 'suitable for the environment' (per manufacturer's opinion). Nothing in the regs, nor anything that you or I have written in this thread, suggests that someone can 'contract out' of that regulation on the basis that it is "up to them".As I said, if you want to fit them there that is up to you but it should not be advised.
