am replacing bathroom pendant light with safe wall light and adding an extractor fan with timer not to be connected to light so it works independently.
is my best option to use a besa box and connectors in the loft above so:
main feed comes in and light and switch go to 1 gang of 2 gang switch.
then from fan take 3 core and earth to triple pole isolator - 3 core from isolator to besa box where 1L core goes to main L, 1 N core to main N and swL connects with swL of 1mm T&E cable runing down to 2nd gang of switch plate so that the 2 gang switch has one for light and one for timed fan but work independently from each other.
Many thanks
Many thanks
