Ignore that, if I turn off at isolation switch and then back on it stays off....but the new switch doesnt turn it on when i press it unless it has a temp shutdown period after turning it off and I need to wait a few minutes
So it stayed off, but nothing happens when I try to turn it on with the switch.
Humidistat still works though as just tested that. I just want to the option to manually turn the fan on. Maybe I should give it half an hour and see if the switch turns it on then
