I'm planning on getting a Vent Axia SELV Humidistat-Timer HT IPX7 extractor fitted in the bathroom.
It will be switched by a 12V light switch at the wall, not by pull cord, the switch will only operate the fan, not the lights.
It will not run in trickle mode, only switched on and off at the wall. The issue is that because it has a humidistat I'm concerned that someone could leave the fan in full on mode all day thinking it was just in humidistat mode and expecting to turn itself off. The switch itself is a special wafer switch and has already been purchased, it does not have any way to know by looking at it if it is on or off.
Basically I just want a fan that ideally has a humidistat, and allows to be controlled exclusively by a wall switch, where the operator can know if the switch is activated or not.
I've attached the wiring diagram for the option I plan to use.
The instructions http://www.vent-axia.com/files/pdf-downloads/F&W Instructions (2)_1.pdf did not enlighten me either.
Cheers
Cheers
