They are only allowed to certify their own work.Do you mean they are only allowed to certify their own work or many will not certify unless they did it themselves?
Sure, there are bent ones in virtually every trade, profession and walk of life - but that obviously does not render their bent practices 'allowed'!There are always bent ones who will take money to falsify official documents.
That is different. After an inspection you will get an Installation Condition Report. After work is done you get an Installation Certificate. Different process, different document.I'm not looking to falsify documents or get a 'bent' certificate.
It's no different to getting an electrical cert when its needed for a rental property or for peace of mind when buying a new house. Everything is checked and if it passes there you go, if it does not then they advise you what needs to be done before it will.
Not allowed toJust to clarify, you're saying that they are not allowed to or are not likely to?
In my profession I oftne check work that I have not done, its legal and saves the client money . . .
This is hard work!
Well, actually, there you don't go, because it isn't the same.It's no different to getting an electrical cert when its needed for a rental property or for peace of mind when buying a new house. Everything is checked and if it passes there you go
Yes, you need to get the answer to that clear in your mind. Although some LABCs seem to be a law unto themselves, what they ought to ask for is an EIC.He said just send him a cert for the electrics and he will send completion cert, which as you say will be needed if I ever sell the house.
So I guess I need to clarify with him whether I need a EIC or EICR?
