Hi all,
Recently purchased house, 1930's. Doesn't seem to have been decorated for years.
I'm getting round to decorating the bathroom. So far all walls are back to brick, and ceiling is down. (All was necessary).
I'm planning on having a quadrant shower approx 950x950 or slightly bigger (no bath).
Tiling all walls floor to ceiling and will be tiling the floor too.
Wall tiles more than likely large format 300x600.
Floor Tiles prob 300x300.
One interior wall will be removed and rebuilt (not a load bearing). Will be using the aeriated 4" thick blocks, then will use soundboard on bedroom side to insulate.
Can you knowledgeable peeps on here tell me if the best way to do it by correcting my points below. I've read seemingly hundreds of posts and just getting more confused.
Plasterboard ceiling - fit using drywall screws.
Get ceiling skimmed.
Aquapanel all walls - As prob large format tiles, I know I will prob need to fix straight onto the Aquapanel. Trouble is, is there a way to insulate the wall too as 2x are exterior walls and I want it as warm as poss (batons an option?) I've read that if big tiles, then plaster or render wont hold the weight.
If we decide not to use larger tiles, then I think I'm gonna render the ext walls, then have plastered, then tile. Drying times arent really an issue as I wont move in for 2/3 months.
Floorboards seem sound so will use say 11mm MDF on top to make rigid (poss thicker - as thick as I can get away with to reduce flex).
Floor Tiles will be prob 300x300 - will use flexible adhesive to fix.
Tiling wall - Start from centres and work out using a baton or something straight then working upwards.
Then install toilet, sink, shower, ceiling fan etc.
This all sound OK?
As I'm learning all this, if you offer advice, I'd be grateful to know WHY too as I'd like to understand the reasoning (at least I'm learning then and not just blindly following instructions).
Oh I hope this is in the right forum as it does have tiling in there - Sorry if not, please feel free to relocate post.
Thanks for reading peeps.
A similar post (this one is more specific I think) that I posted is here:
http://www.diynot.com/forums/viewtopic.php?p=1886542#1886542
I have taken the contents of this on board and hopefully this one can be answered as well as that.
This all sound OK?
