Bathroom Wiring disaster
You have committed the number one most common mistake.
No - it was Daisy's brother who did that.
And actually it was #2 mistake - #1 was him thinking that not knowing how something works was not in any way a reason to not fiddle with it.
:D
Lovely.
BTW - have you seen what those fairly good quality Duraplug rubber plugs and sockets can do when you get them hot enough ?
Going back "some years", it was common for farmers to have those old oil filled Pickhill Bantam welders - great bits of kit when you wanted to wind the arc up and get a decent blob of metal glued on. Of course, they didn't run too well through a 13A fuse which - rather inconveniently - would blow. Now every fool knows that a 1/4" bolt is a perfect replacement ...
Well I got to see what happened to the rubber socket on the end of an extension. Well if you imagine you've cut a banana in half (across the middle, not lengthways), are holding the stalk, and peel down the skin - well that's about what the casing had done, and stuck up in the middle like flower stamens were what was left of the terminals (blocks of brass on a stick of wire).
Apparently it was "quite spectacular" when it let go.
I have an old oil-filled Oxford welder.
The plug on it (which I think might well be a Duraplug) does not have a 13A fuse in it - it has a length of 15A fusewire soldered across the fuseholder.
Put the cuffs on and lead me away....
In my defence I would say that I did that as a callow youth when I knew not what I know now, and I haven't used the thing for years. Mrs Sheds thinks I should get rid of it. I think I should install a few strategically placed 16A 60309s and change the plug "just in case".
Women vs men, eh? :whistle:
I've seen lead solder in a 3036..... Must have been more of a pig to terminate than a 3036 is using standard fusewire...
By your own admission, having self confessed to a flagrant disregard of the regulations you should be publicly humiliated, all your property seized, and you should be left destitute and longing for a decent pothole to go and live in. Only joking :mrgreen:
I recall that Dad had a large quantity of 13A fuses many years ago - from decades spent replacing them with smaller sizes (in reference to another thread, not the plural there :whistle:). That stock (kept in an old yellow Kodak film roll box) started going down somewhat when he got the welder. At some point he put a C16 MCB and a 16A socket in a metal box and stuck that in the garage RFC.
While not technically wiring regs compliant, it's a pragmatic solution without any real hazard associated with it.
