Oh ok cheers mate but on the manual shows slightly different...
After connect jumper I have to do everything within 10mins ? If remove the battery do i need re learn this ?
No need to re-learn. Forget instructions, pyronix make it up as they go along. Walk test the detector individually at the end to test. Walk Test? Press Yes Then No then enter the zone number. It'll bleep each time it triggers.
