As I said, I've never had one but, yes, my understanding (right or wrong!) is that all the cooling mechanism is 'at the back' and that cold air is blown into the cavity, the idea being that most ice formation is not inside the cavity. I'm nor sure I fully understand that, given that I would have expected any moisture within the cavity to turn to ice there, given the temperature within that cavity, just as it does in one without auto-defrosting. There are clearly aspects that I don't fully understand!Our latest one, is an upright auto-defrost. From what I have gathered, the cooling elements and the defrost section, are all concentrated at the back - so it seems unlikely it would much influence the main contents of the freezer.
However, whatever the details, auto-defrosting obviously implies that the cooling periodically stops for a period of time (of whatever duration), so I would imagine that the (air) temp within the cavity would reflect that.
Interesting. I've only had (and still have) only the first two of those. Another difference between upright and chest is that, particularly if it does not have draws or 'doors' (but to a fair extent even if it does), opening the door of an upright freezer resukts in it rapidly filling up with room temperature air. Access and 'the ice at the bottom' are certainly issues with chest freezers, but they do generally have much larger capacity than any common (or 'accommodatable') upright one!Having had all three types of freezer chest, upright, and now auto-defrost upright, the only difference I notice is the convenience of access, plus the lack of masses of ice forming in the base of a chest type freezer.
Maybe. As I said, I have no experience of these 'defrost cycles', although, as above, they presumably must have at least some impact on the temp within the cavity.I would guess the defrost cycle is very brief, and so hardly makes any difference to how long it can last without power. Insulation thickness on over old chest freezer was somewhat thicker, but insulation has supposedly improved in the 50 years since we had a chest freezer.
