Hi all. Just fitted a new Diverter Valve assembly to an ageing Baxi 105e, and after some initial problems with leaks from the pressure sensing pipes, it was all sound and leak-free, so ready to fire up. Yesterday it started and ran to temperature normally, but this morning, after the burner lit for central heating, it went out after only a minute or so. I tried a work-around that i used last Winter, which is to turn on the hot tap nearby at the kitchen sink and then when i turn that tap off after a couple of minutes running the hot water, the burner for the central heating stays On. It stays on as long as required. I've no idea where to look for the cause of this problem, and i'm definitely hoping that it's not a Diverter problem as that's supposed to be all fixed !
