Thanks, yep it was horribly gunged up with all sorts - matted. I got it cleaned up and replaced everything including a rigid filling loop, and that was the start of hours of confused faffing about, as the boiler would not re-fill through the loop at all. I took the loop off again, filter out, couldn't see anything amiss and was pretty stumped. Hours later...removed the loop to test in the sink and it seemed dodgy, ie not passing a flow of tap-water. I made up a bodged arrangement of garden hose, a length of 15mm copper pipe, jubilee clip and a flexible hose to fit to the CH return valve, all connected to the outdoor tap, and only a gentle flow got water going into the boiler and re-pressurizing it with ease. So the loop is definitely knackered and will be replaced. Onwards and upwards....Sounds as if it is partially blocked/restricted, hence the poor initial flow through the system.
