Hi Chris,
Ok, I will check the electrolytics. I have an ESR meter at work so can test them with that, after checking that they are discharged of course!
Interestingly, last night after the system had been switched off for a while, I tried powering up the boiler again and it worked ok again for about 10 seconds, i.e. the flame LED lit and the boiler fired up, but then the Fan fault LED started flashing again.
Anyway, now I can safely rule out a blocked venturi or flue, I guess it could only be the aps or pcb that are faulty. Would it be ok for me to connect the switch wires to the aps together temporarily and see if the fault then goes away, in order to determine for certain whether the aps is being activated properly? If so, should I connect the Common and NO switch wires together?
I have booked this afternoon off work so I can go home and have a look at the problem in more detail, so any tips/troubleshooting advice would be greatly appreciated.
