Please Help,
I have Baxi 105e combi boiler approx 3 years old when you run the hot water for approx 3 mins it the flame cuts out and you then get cold water after approx 1min it then powers up starting the whole cycle again resulting in a luke warm bath. The central heating side seems ok could anyone please point me in the right direction.
Thanks.
over the years any diluted debris from the rads dry out and bake inside the plate heat exchanger. Power flushing doesn't prevent this. You could install a filter on the return to prevent it happening again. You are best off taking the plate heat exchanger out and buying some cleaner from your local B & Q and that will get you going.
what utter garbage is this the standard of baxi engineers here in the north?
