You have to drain boiler and remove pump head to check impeller for blockages and the unseize in most cases.
Very naughty you are Tony. Invariably the poster will have a leak when he removes the pump head, flood the PCB area, even disturb the connection at the heat exchanger.
Surely, you are not advising the lad should start tinkering with the boiler
I think I've changed most parts on this thing now. I've just replaced the 3 way motor/actuator. Couple months back the dhw diverted valve and the one behind that??
Added an external expansion vessel.
Just after a few pointers on getting the heat exchanger out to clean it out. I've got 4 gaskets on order and an getting some x800. Just wondered if I ran the x800 through the system would it unblock the heat exchanger?
