Baxi 105e Leak
The diverter design appears very similar to the Alpha 240 series probably made by Immergas.
If the leak is on the diverter section refurb kit 1000760 (Alpha part no. about £30.00) may well fit.
And if the leak is on the front diaphragm section refurb kit 1000765 (Aplha part no. about £15.00) may fit.
alpha kit defo works on the diaphragm section cos thats all i use, no idea about the diverter section though
Hi Folks!
I have just purchased a new diverter valve manifold assembly but have a question for you before I attempt to fit it.
I know that the DHW diaphragm can be replaced by just turning off cold water supply to boiler and then undoing sink taps to drain water. Does the same procedure apply to replacing the entire assembly?
It states in Baxi manual that the 'primary circuit' needs to be drained. Is this absolutely neccesary, and if so what's the easiest way of doing it?
Alternatively, if this doesn't need to be done then what should I do before removing the old one, in order to prevent water spilling everywhere?
Thanks in advance for you help. :)
Rob.
No
Shut all isolating valves and drain off via boiler drain cock..Also remove the blanking plug on C/H flow valve to get the last drops out
robbierazz said:
Alternatively, if this doesn't need to be done then what should I do before removing the old one, in order to prevent water spilling everywhere??
As Above
Did you get a couple of new 3/4 washers. :idea:
Hi Poxi,
Yes, I did obtain some 3/4 washers, as I was advised to do this by someone else. I will be sure to fit the new washers when replacing the manifold assembly.
Many thanks for your help. :D
Rob.
hello this is my first post and thank you for persivering with me
i have a small drip on my baxi combi boiler. i have located the leak is coming from the 22mm pipe on the left hand side near the heat exchanger. the conection is not a normal compresion joint. instead it has a clip holding the conection. is there a seal inside this joint and is it an easy job to do and if it has a seal what do i ask for when purchaseing the seal. there isnt much room to get my hand i so can the side panel be removed
Start a new post.
State the boiler model and age and add any other relevant info.
dont know if you can see this i have water leaking from the hole as the arrow shows in picture http://prntscr.com/682hut can anyone help, is this what everyone else i on about does the bolt need tightening or is it something else[/url]
You need a diaphragm repair kit. Google it. Easy and cheep repair
Buy one from Internet unless you want to quibble over a couple of quid
Has everyone lost their sense of proportion. Quite happy to buy the latest car on finance but will scream merry hell over a £100 part
God forbid an honest tradesman will make some money on a job.... The greedy so and so's
  • Thanks
Reactions: DP
