Ok I cant hear anymore coming from the RADS and the water is now clear, I can try and hose out the draincapp to outside and use the filler to clean thru and let you knw if anything changes.
REST boiler you mean hold the on/off dial fully to the left for 2 seconds and let go, I've not seen that do anything.
I hear the boiler trying to kick in more when the hot tap is on but low pressure light comes on when it fails to ignite, when I try to fire RADS up it clicks, I hear hum (I assume is the fan) and I hear the pump if I put ear to turning slowly but again low pressure light comes on flashing. The pressure is set to 1 bar, its done this a few times before and I on/off a few times then I hear a trickle of water and I know its firing, I then add a little more water and it fires.
Just drained a full basin full while filling up at same time and still same, do I need to do a lot more to be sure. Also the pump is too hot to touch is that normal?
