The most important part is you MUST leave a drain point open as you pressurise the vessel, you will get a fair bit more water as you pump it up as you are now forcing the water from the vessel, when the water stops coming out then you will no be pressurising the vessel, take to 0.8 Bar then close the drain point and remove the pump
No it wont and if you close the isolationg valves they will most likely leak when you open them again, the water in the radiators will be held in a vaccum
Just a quick question boiler guys , my boiler is working great now 1 bar cold 1.7 bar hot . What would have happened if I had put too much pressure in the expansion vessel ?
