Hi can anyone give me a basic step by step instruction on replacing the plate heat exchanger. The fault is hot water running hot then cold and hot again with the boiler cycling on and off. DHW fine. All the research I have done points to this being sludged up. Have seen the part for around £50. A couple of questions - do I need to order any extra o rings etc. And also what is the best way to treat the water system after I have replaced it.
Any thoughts would be appreciated but a step by step guide would be great.
Also, does anyone know the correct technique for diagnosing this - I find it a bit baffling and have tried to understand the theory behind how it works. Managed to confirm the thermistor is operating correctly but no other tests to prove it.
Help.
Help.
