If changing yourself, before removing old PCB turn stats to 0 and selector to off, then using a screwdriver do the same with the replacement board and it will simply slip on, be carefull not to force anything, when you have fitted the replacement try turning all the knobs and make sure they turn freely, if they are stiff dont force them, it is possible to get the knob spindles 180 degrees out
Refurbished PCB fitted this afternoon, everything appears to be good. Ran heating for 90 mins and no return of fault, as yet (fingers crossed). Stat buttons seem to be a bit stiffer than before, but you can still turn them freely enough. Thanks to all
