Then there is nothing wrong with the pump proving switch you will probably find the plate heat exchanger is blocked or the boiler isint recognising the hot water demand.
SO that was wrong, then...yes central heating works ok, but if i do not push the pin manually do not get any hot water because boiler will not fire up.
What pin are you pushing? The pin is operated by the diaphragm. The switch doesn't have a pin.
The pin presses aginst a lever iirc, which operates the switch which has a small plastic bit sticking out under the lever.
If you mean the pin isn't coming out far enough to operate the switch, then there could be several reasons for that.
How far is it moving and, is it the same for CH as HW? (As asked before)
